how insert an incident using background script with impact and urgency
hemanthkumar
Kilo Expert
Alikutty A
Tera Sage
You can try this in a background script
inc.initialize();
inc.caller_id = gs.getUserID();
inc.short_description = 'test';
inc.impact =3;
inc.urgency =3;
inc.insert();
Thank You
Please Hit Like, Helpful or Correct depending on the impact of response
Hi Hemanth,
Adding to what Alikutty says,
inc.initialize();
inc.description = 'test';
inc.impact =3;
inc.urgency =3;
inc.insert();
description is   mandatory field most of the times.
Shariq
Ankit_Pandey
Hi Hemanath,
inc.initialize();
var inc=new GlideRecord('incident');
inc.setValue('short_description', 'This incident is generated by Script');
inc.setValue('caller_id',gs.getUserID());
inc.insert();
Please find below the query for incident creation.
1. You can use this query in the fix script to insert it manually.
2. Also you can use it in scheduled jobs scripts to insert the incident at any particular time.
