How much time it takes for Indexing a Field?
Chaisai
Kilo Expert
Hello, We have created a Transform map in which we have put Coalesce on the Asset table field "Serial Number", But whenever we are trying to index the field it is not getting done as we have tried multiple times, got a pop up like indexing has been scheduled but still not getting done. Also, it will be helpful like how much time it takes for getting Indexing done.
Thanks in advance!
Is it your own instance? Which version are you using?
I suggest you to wait some times, if nothing will happen, open a request to ServiceNow guy, they will do a check for you.
Cheers
Alberto
Any update on this?
If I have answered your question, please mark my response as correct so that others with the same question in the future can find it quickly and that it gets removed from the Unanswered list.
Thank you
Cheers
Alberto
Alikutty A
Tera Sage
Open a ticket in HI service portal and they will get the index added from the backend. All tables have an index limitation of 64 entries, so they may be able to figure it out if there is an error while adding it.
