How set a default value using dictionary entry
Sowmya20
I have the variable called Audit, it should be "No" by default. I am trying add the default value using dictionary.
Is there anything I'm missing to add.
Thanks.
17 REPLIES 17
Raghav Sharma24
Giga Patron
Can you right-click on that field and select "watch".
After doing this just reload the form from header right click option (reload form) and check if some other script is overriding your default value.
You will only have option to watch field if you have application navigator on left of form.
There is no other scrpt overriding.
Ok, can you check in sys_choice table that there is no leading or trailing space with "no"  value by mistake, as that may also cause issues.
