how to Add a state to the change state model
suprakash
Giga Expert
I added two states draft and work in progress as the   process given in   Add a state to the change state model
in my case the first step is draft and second state will be work in progress after that there are other states
i have to do in a way that from draft the state will only be updated to work in progress. After it comes to work in progress then it may go to another state for . this is emergency change request type
But i cannot understand how to edit the script include ChangeRequestStateModel_emergency.
Need help
Hi Suprakash,
'Review' is a OOB Change request state, so you do not have to define 'canMove' or 'moving' function separately for review. In your case the code will below:
work_in_progress: {
              nextState: [ "review" ],
              review: {
                      moving: function() {
                              return this.toReview_moving();
                      canMove: function() {
                              return this.toReview_canMove();
I hope this helps.Please mark correct/helpful based on impact
23 REPLIES 23
Hi Saptashwa,
Sitting over here, it is very difficult for me to debug what is causing the issue. All I can do is to show you how to achieve if you want to add newly generated states. The rest you have to do it by yourself.
Lastly, I can suggest to use the OOB ''ChangeRequestStateHandlerSNC' and modify whatever you want in 'ChangeRequestStateHandler', as I have mentioned many more times.
Can I share you my instance details so that you can look into the matter?
Hi Saptashwa,
Unfortunately, currently I am bit Busy with My work. I will try after some days on your personal instance once I get Time. In Between You can start Updating your script include as per my responses above in the Thread.
suprakash: If you have some time can you please help Saptashwa ...... as the issue for both of you are same
In my case also its not working Amlan.
I am working on it.
If its get solved I will let both of you Know.
The thing i noticed after trying   is that if we want to add any particular or insert any particular states in between the ootb states   keeping the ootb states active , then its working fine. But if we want to deactivate the ootb states and create all the new states in that way, then its not working
