‎02-17-2025 06:43 AM
I got Requirement like if I submit a catalog form then user or user email needs to be added in Microsoft entra group.
please help me on this. how I can configure the flow designer what are all the plugin I need to install and need steps on configuring the both side.
thanks in advance,
Prasanna
‎02-17-2025 07:11 AM
Hello @prasannah
To achieve this requirement, you can use the Microsoft Entra ID Spoke in ServiceNow's Flow Designer.
Prerequisites:
1) Ensure you have a ServiceNow instance with the necessary permissions.
2) You need a Microsoft Entra subscription.
3) Install the following plugins in ServiceNow:
-> Microsoft Entra ID Spoke - Configure ServiceNow for automatic user provisioning with Microsoft Entra ID - Microsoft Entra ID | ...
-> Integration Commons for CMDB
Now your flow will be as:
Trigger will be when a catalog item is submitted.
First use a Lookup User action to find the user based on the email provided in the catalog form. If user reference field is provided in catalog item then you can skip this step and directly use from req item variable value by dot walk and pass to next step.
Use the Add User to Group action from the Microsoft Entra ID Spoke to add the user to the specified group (you can take from form or if you have fix group pass that value)
Thanks & Regards
Viraj Hudlikar.
‎08-19-2026 05:54 PM
Sorry. Is it mandatory then to provide the Entra GUID of the user with the "Add User to Group" action? It cannot be UPN or email?
‎11-19-2025 04:03 PM
what about adding multiple users from a list collector variable using the Add Users to Group function in the Spoke. Struggling to convert the memberlist to the azure values that the spoke needs. Keep getting errors like
"Exception while executing request: Could not deserialize value from sys_flow_value with sys_id "
when trying to pass list to a custom action to get the objectIds.
‎11-19-2025 04:16 PM
‎02-26-2025 03:12 PM
"Action Status": {
"code": 1,
"message": "Error: Unknown Error (Process Automation.bc3088ea0bd4a110cfed40976877b252; line 6)"
‎08-13-2025 11:18 PM
Facing Same issue
"Action Status": {
"code": 1,
