02-16-2022 12:25 AM
Please suggest me how to add choice values from array.
Array CHOICEVALUES[value,label]
[chat,Chat,voice_call,Voice Call,walk-in,Walk In,email_fire,Email Fire]
Issue : Now How to add choices from Workspace client script using with for-loop
function onClick(g_form) {
var fields = [{
type: 'choice',
label: getMessage('invoice type'),
value: getMessage(' -- Select -- '),
choices: [{
displayValue: '',
value: ''
mandatory: true
type: 'string',
label: getMessage('Invoicer'),
value: g_form.getDisplayValue('consumer'),
readonly: true,
g_modal.showFields({
title: "Product for Invoice",
fields: fields,
}).then(function(fieldValues) {
g_form.setValue('short_description', fieldValues.updatedFields[1].value);
var ga = new GlideAjax('CDAInvoiceProcessor');
ga.addParam('sysparm_name', 'getInvoiceTypes');
ga.getXML(populateChoiceeField);
function populateChoiceeField(response) {
var msg = response.responseXML.documentElement.getAttribute('answer').toString();
if (msg != '') {
msg = msg.split(',');
if (msg.length > 0) {
g_form.clearOptions(fieldValues.updatedFields[0].name);
g_form.addOption(fieldValues.updatedFields[0].name, '', '-- None --');
for (var i = 0; i < msg.length; i = i + 2) {
fieldValues.updatedFields[0].value= msg[i];
fieldValues.updatedFields[0].displayValue= msg[i+1];
02-17-2022 05:52 AM
if you wish to add None then do this
Script Include:
var arr = [];
// to add None
arr.push({
"value":"",
"displayValue":"-- None --"
var DWN = new GlideRecord("u_customer");
DWN.addQuery("u_active", true);
DWN.addQuery("u_name", "Customer Specific Type");
DWN.addQuery('u_customer',' b70c0f830f37330013a831ef68767e33');
DWN.query();
if (DWN.next()) {
PARMS = DWN.u_parms.split(',');
gs.info("PARMS " + PARMS.length + "--" + PARMS);
for (var i = 0; i < PARMS.length; i++) {
var obj = {};
var choice = new GlideRecord('sys_choice');
choice.addQuery('name', 'incident');
choice.addQuery('language', 'en');
choice.addQuery('element', 'contact_type');
choice.addQuery('inactive', false);
choice.addQuery('value', PARMS[i]);
choice.query();
if (choice.next()) {
obj["value"] = choice.value.toString();
obj["displayValue"] = choice.label.toString();
arr.push(obj);
var result = {};
result["choices"] = arr;
return JSON.stringify(result);
Workspace client script:
var fields = [];
fields.push({
type: 'string',
readonly: true,
ga.getXMLAnswer(populateChoiceeField);
var msg = response;
var answer = JSON.parse(msg);
fields.push({
type: 'choice',
choices: answer.choices,
mandatory: true
fields: fields,
02-17-2022 03:12 AM
what are you returning from script include?
are you returning array OR array of JSON object containing label and value?
02-17-2022 03:49 AM
script-include returning array
DWN.query();
if (DWN.next()) {
choice.query();
value = choice.value.toString();
label = choice.label.toString();
CHOICEVALUES.push([value, label]);
return CHOICEVALUES.toString();
02-17-2022 04:11 AM
update as this and it should work
share the updates
Script Include:
var arr = [];
DWN.query();
if (DWN.next()) {
choice.query();
var obj = {};
arr.push(obj);
var result = {};
var fields = [];
fields.push({
type: 'string',
readonly: true,
fields.push({
type: 'choice',
value: (answer.choices && answer.choices.length > 0) ? answer.choices[0].value : '',
mandatory: true
fields: fields,
02-17-2022 04:36 AM
02-17-2022 04:42 AM
did you debug?
what came in alert? share that
update as this
var fields = [];
fields.push({
type: 'string',
readonly: true,
alert(response);
var msg = response;
fields.push({
type: 'choice',
mandatory: true
fields: fields,
