02-16-2022 12:25 AM
Please suggest me how to add choice values from array.
Array CHOICEVALUES[value,label]
[chat,Chat,voice_call,Voice Call,walk-in,Walk In,email_fire,Email Fire]
Issue : Now How to add choices from Workspace client script using with for-loop
function onClick(g_form) {
var fields = [{
type: 'choice',
label: getMessage('invoice type'),
value: getMessage(' -- Select -- '),
choices: [{
displayValue: '',
value: ''
mandatory: true
type: 'string',
label: getMessage('Invoicer'),
value: g_form.getDisplayValue('consumer'),
readonly: true,
g_modal.showFields({
title: "Product for Invoice",
fields: fields,
}).then(function(fieldValues) {
g_form.setValue('short_description', fieldValues.updatedFields[1].value);
var ga = new GlideAjax('CDAInvoiceProcessor');
ga.addParam('sysparm_name', 'getInvoiceTypes');
ga.getXML(populateChoiceeField);
function populateChoiceeField(response) {
var msg = response.responseXML.documentElement.getAttribute('answer').toString();
if (msg != '') {
msg = msg.split(',');
if (msg.length > 0) {
g_form.clearOptions(fieldValues.updatedFields[0].name);
g_form.addOption(fieldValues.updatedFields[0].name, '', '-- None --');
for (var i = 0; i < msg.length; i = i + 2) {
fieldValues.updatedFields[0].value= msg[i];
fieldValues.updatedFields[0].displayValue= msg[i+1];
02-17-2022 05:52 AM
if you wish to add None then do this
Script Include:
var arr = [];
// to add None
arr.push({
"value":"",
"displayValue":"-- None --"
var DWN = new GlideRecord("u_customer");
DWN.addQuery("u_active", true);
DWN.addQuery("u_name", "Customer Specific Type");
DWN.addQuery('u_customer',' b70c0f830f37330013a831ef68767e33');
DWN.query();
if (DWN.next()) {
PARMS = DWN.u_parms.split(',');
gs.info("PARMS " + PARMS.length + "--" + PARMS);
for (var i = 0; i < PARMS.length; i++) {
var obj = {};
var choice = new GlideRecord('sys_choice');
choice.addQuery('name', 'incident');
choice.addQuery('language', 'en');
choice.addQuery('element', 'contact_type');
choice.addQuery('inactive', false);
choice.addQuery('value', PARMS[i]);
choice.query();
if (choice.next()) {
obj["value"] = choice.value.toString();
obj["displayValue"] = choice.label.toString();
arr.push(obj);
var result = {};
result["choices"] = arr;
return JSON.stringify(result);
Workspace client script:
var fields = [];
fields.push({
type: 'string',
readonly: true,
ga.getXMLAnswer(populateChoiceeField);
var msg = response;
var answer = JSON.parse(msg);
fields.push({
type: 'choice',
choices: answer.choices,
mandatory: true
fields: fields,
02-17-2022 05:52 AM
Script Include:
var arr = [];
// to add None
arr.push({
"value":"",
DWN.query();
if (DWN.next()) {
var obj = {};
choice.query();
arr.push(obj);
var result = {};
var fields = [];
fields.push({
type: 'string',
readonly: true,
var msg = response;
fields.push({
type: 'choice',
mandatory: true
fields: fields,
02-17-2022 05:59 AM
02-17-2022 06:00 AM
Glad to help.
Happy learning.
02-17-2022 06:47 AM
I just created a blog for this so that it helps community members.
Populating dynamic choices in workspace form pane for choice field type
Do visit and mark it helpful and also bookmark it.
02-17-2022 06:08 AM
Small correction
comment out this line
