How to add column fields in List view - In Portal
chanikya
How to add more columns here -closed date, Created By, Opened By
Hey Chanikya,
There is no Mobile view by default for the sc_req_item table and so you have to create one using the steps below:
Steps to add mobile list view
  1. Go to System UI -> Views
  2. Find the Mobile view
  3. On the lists tab add the sc_req_item table
  4. Open the new sc_req_item sys_ui_list record
  5. Add the elements and their position as you would like them to appear.
There is no Mobile view by default for sc_req_item and so it uses the task one.
Hope this helps!
25 REPLIES 25
In RITM , i think there is only 2 view's are available there,
1.Default
2.Self -Service
we didn't have SP view
Try changing both the views and check.
Robert Webb1
Hey Chanikya,
My apologies as the drill-down is actually using the mobile list view for columns display.
Steps to change
Hope this helps
1.Default
2.Self -Service
Hey Chanikya,
Steps to change
Hope this helps!
