How to add column fields in List view - In Portal
chanikya
How to add more columns here -closed date, Created By, Opened By
Hey Chanikya,
There is no Mobile view by default for the sc_req_item table and so you have to create one using the steps below:
Steps to add mobile list view
  1. Go to System UI -> Views
  2. Find the Mobile view
  3. On the lists tab add the sc_req_item table
  4. Open the new sc_req_item sys_ui_list record
  5. Add the elements and their position as you would like them to appear.
There is no Mobile view by default for sc_req_item and so it uses the task one.
Hope this helps!
25 REPLIES 25
if it is okay with you , can you login my PDI
dev48363  test/123
Take a look now
earlier i seen that there is no Mobile view, so suddenly from where you have got mobile view
could you please explain it
Can you please tell me how to get mobile view in list of RITM In my instance there are showing only 2-views. Default, self-service.
Hey Chanikya,
Hope this helps!
