How to add hyperlink in additional comments field in the flow designer
Prachi Tikhe
Need help with hyperlink to display in additional comments but <a href> not working. This is in the flow desigining.
then add an attribute called target="_blank" to your href just like below example which will open your link in new tab
<a href="your link" target="_blank">click here</a>
please mark my answer correct if it helps you
Nasreen2
Hi Prachi,
Since you marked this solution as Accepted, Could you elaborate and show the exact syntax you used to add a hyperlink in between some text in additional comments section of flow designer?
