07-16-2023 11:45 PM
How to add hyperlink in catalog (checkbox field in catalog item) item.
Thanks and Regards,
Chandan Patra
07-17-2023 12:21 AM
Hello @chandan31
have you referred second thread. the requirement is quite similar.
if your requirement is to show hyper link when checkbox clicked, you can do it via on change client script.
refer: Solved: hyperlink in on-change client script - ServiceNow Community
Please hit the thumb and Mark as correct based on Impact!!
Kind Regards,
Ravi Chandra.
07-17-2023 01:01 AM
did you try to create checkbox variable and show some field message on form load?
07-17-2023 01:01 AM
07-17-2023 01:07 AM
yes
07-17-2023 01:09 AM
I have applied below solution but it is not working
07-17-2023 01:13 AM
Hi @chandan31
try placing in as html format like <a> link </a>
I see you added direct link.
Kind Regards,
Ravi Chandra.
07-17-2023 01:17 AM
