How to add user to group (sys_user_group) using Flow designer
Kifrez
Hi, could you please let me know if you have used/added user from sys_user table to group (sys_user_group) using Flow Designer?
If so, how do you do it? What action do you use ? I can't seem to find the action
Or does anyone know how to automate adding user to a group within ServiceNow?
sk8
Kilo Expert
Hi Freddy,
To add the user to a group in Flow designer follow the below steps:
1. Add create or update record action.
2. Select Table name - Group member [sys_user_grmember].
3. Now select the group field and select the group in which you want to add a user.
4. Select the user field and select the user to add to the group.
Please mark answer as helpful/correct if it works for you.
Sk
15 REPLIES 15
hi @Ed Hefford , do you mind provide your flow?
Also, how should I do a look up?
