How to Auto-Close Resolved Cases (5 Business Days)
Rob Sestito
Hey Everyone!
So, I have a scheduled job that runs - to auto-close resolved cases. When it first was put together for Go-Live, it was supposed to be set for 5 business days, however (before i took this current position), it was set for 1 business day as a test and then never touched again. (seems silly)..
Here are the conditions and script to current job:
Run: Periodically
Repeat Intervals: [Days] 0
Hours: 01:00:00
Run Script:
// Close incidents after 5 business days
var days = -7;
// Business days exclude Saturday and Sunday
var day = new GlideDateTime(gs.nowDateTime());
//var weekday = day.getDayOfWeek();
//days = days - 2;
day.addDays(days);
// Find resolved incidents
gs.log('SJ Auto-close hr cases looking for cases resolved before ' + day.getDisplayValue());
var hr_case = new GlideRecord('hr_case');
hr_case.addQuery('state', '20');
hr_case.addQuery('sys_updated_on', '<=', day);
hr_case.query();
while (hr_case.next()) {
gs.log('SJ Auto-close cases found resolved case ' + hr_case.number + '. Was updated on ' + hr_case.sys_updated_on);
hr_case.state = '3';
hr_case.update();
Now originally, var days = -7; was set to -1 and I was told if I want to do 5 business days excluding weekend, then I needed to set that to the -7.
System Properties, Number of days (integer) after which Resolved incidents are automatically closed. Zero (0) disables this feature: This is set to 5 (which I changed as well, before it was set to 1).
During some testing, I changed the System properties "number of days" to 2 and left the script as it was to start with. A Case was auto closed after 2 days, 6 hours, 44 minutes.
Then I changed the system properties "number of days" to 5 - and change the script from var days = -1; to var days = -7;
And then my case auto closed 3 days. 2 hours, and 29 min.
From the information I have provided, is anyone able to see/notice what I need to change in order to get this corrected? (not sure if it matters, but my first test was on a Monday, second test was on a Thursday).
Thanks so much in advance!
-Rob
Rob Sestito
Much later on this - but I went a different route on this.
Ended up adding in all our company's schedules within the system. Edited Workflow HRI Case User Acceptance - also created a system property which looks at HR Core Case, rather than the OOB property that controls the Incident Table.
Stages that I had to adjust were:
  1. Timer
  • Duration
  • Schedule Based on
  • Schedule
Then I also adjust the notification that goes out as well to fit our format. Also, OOB this sends the notifications to the Subject Person. I changed that to send to Requestor.
From this, I was able to control when HR Cases auto-close within 5 business days.
18 REPLIES 18
Yes..
replace that line with var ps =5; and modify field names and queries accordingly..
Sadasiva
Please mark helpful/ correct based on the impact
Goran WitchDoc
I did a post about it here, 3 Business days, but that is easy to just change:
How to close ticket after 3 business days
//göran
Thanks for the reply and information to your post Goran!
I just checked out the Relative Durations from my SN Test Instance and here is what is shown:
// 3 business days by 4pm if before 10am
var days = 3;
// If the current time is after 10:00, add another day
if (calculator.isAfter(calculator.startDateTime, "10:00:00")) {
    days++;
calculator.calcRelativeDueDate(calculator.startDateTime, days, "16:00:00");
Which above shows very true to what happened to my last test that I stated in my original post.
Could/Should I change this? Making the script look to 5 business days instead of 3? Along with all other changes that have been provided in this post?
You can just make your own 5 days duration and keep the oob 3 days alone 😃
Thanks Goran,
I actually went through your link you sent me about this type of Discussion (How to close ticket after 3 business days ) and created new ones to see if I can do some testing with that - and making the OOB 3 day to false.
Going to give that a try - Thanks again!
-Rob
