How to call a flow from another flow in ServiceNow
hemanth16
I have a catalog item one all the flow is completed I need call another flow
I am giving if condition as task is complete then start the flow
How can I add the flow ?
Any suggestions!
Thanks in Advance!!
You just have to pass the Flow inputs and use them in subflow
hemanth16
Hi Sai,
Thanks for the response
while I am creating Subflow it is asking input and output can you help me on that ? I am new for this
Thanks in Advance!!
Peter Groft
You can't call a flow from another flow but you can call a subflow from a flow. Create a subflow for those two flows and theynyou can call the subflow from that third flow.
Hope This Works,
Peter
Ubada Barmawar
Hi
I can say there are two ways to call flow/subflow in a flow.
  1. create a subflow and pass the triggered record reference to subflow (subflow inputs --> reference.requested) item
  2. if you want to call FLOW inside a flow, go to user preferences in flow and select the "Include flows with triggers in subflow picker" option.
 hope this resolves your issue. if it did, give a thumbs up or mark as correct solution.
regards,
Ubada Barmawar.
