How to call script include in flow designer to call flow again
shweta14
I have requirement to call flow inside flow and add approval
I am creating multiple RITM based on list collector field and want to add same flow on each RITM to add approval and update record.
added below script include but not working
same script if run in background then it will work
script include :
var StartFlow = Class.create();
StartFlow.prototype = {
   // initialize: function() {
        startflow:function() {
    try {
        var gr=new GlideRecord('sc_req_item');
        if(gr.get('sys_id')){
       // gr.get('sys_id');
        var inputs = {};
        inputs['table_name'] = 'sc_req_item';
        inputs['request_item'] = gr; // GlideRecord of table: sc_req_item
        // Start Asynchronously: Uncomment to run in background.
        // sn_fd.FlowAPI.getRunner().flow('global.test_for_item').inBackground().withInputs(inputs).run();
        // Execute Synchronously: Run in foreground.
        sn_fd.FlowAPI.getRunner().flow('global.test_for_item').inForeground().withInputs(inputs).run();
    } catch (ex) {
        var message = ex.getMessage();
        gs.error(message);
    type: 'StartFlow'
how to achieve this? @Anil Lande
how to pass values or input in script include for this flow?
log shows undefined for variable value
you may need to pass it in the function parameter.
when i am adding parameter then flow is not getting called
Hi @shweta14 ,
You have to create one action and in that action you need to create one script type action and in that you need to call script include sample code
new scriptInclude().functionName();
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
