How to call Script Include using Jelly Script ?
Chandra51
<g:ui_reference name="active=true" id="name" table="sys_user_group"/>
<g2:evaluate>
var out= new SurveyUtilities().getSurvey();
</g2:evaluate>
<p>${gs.getMessage(out)}</p>
</j:jelly>
I am getting output like this.
Can you explain what you are trying to achieve here? - I have prepared a HTML data (JavaScript code prepares this HTML code) in that script include & I need to show that in dashboard using dynamic content blocks
the script include function what and what you want to do with the values - When I load the dashboard then it should run the script include
Are you saying the value which is coming from the script include function should be set in that text box? - The Value from script include needs to be set on dashboard directly
Megha Padale
Giga Guru
Adding to Pratiksha, check this
https://community.servicenow.com/community?id=community_question&sys_id=0299ebb5dbae2700b1b102d5ca96...
If my answer helped you in any way, mark answer as helpful and correct.
Thanks and regards,
Megha.
