How to call server side data on html side?
Sin
Giga Expert
Guys am trying to show `name` field from `announcement` table on html side using `<marquee></marquee>` field.
Server script:
(function() {
var announce=new GlideRecord('announcement');
announce.addQuery('active=true');
announce.query();
while(announce.next()){
data.announcement= announce.name;
console.log(data.announcement);// got data here
HTML code:
<div>
<marquee>{{data.announcement}}</marquee>
</div>
I am not getting the data on html code. What I did wrong here?
If I have multiple datas on name field how can I loop it?
Sin
Giga Expert
The following code worked me for showing marquee data from array and object.
serverside:
(function() {
data.arr = [];
announce.query();
var record={};
var display_value='';
display_value = announce.getValue('name') ;
record.display_field=display_value;
data.arr.push(record);
Html side:
<div>
<marquee><b ng-repeat='val in data.arr'><label>{{val.display_field}}</label></b></marquee>
</div>
13 REPLIES 13
yea tried 😞
Shweta KHAJAPUR
As you are directly using the data.announcement in HTML, it'll try to fetch the once the form load. Try something as below for testing purpose,
(function() {
data.announcement = 'test';
announce.query();
Omkar Mone
Hi
Got it , Try the below in Server Side Script :-
(function() {
  /* populate the 'data' object */
  /* e.g., data.table = $sp.getValue('table'); */
	var arr=[];
announce.query();
arr.push( announce.name);
data.announcement = arr.toString();
HTML (same):-
<div>
<!-- your widget template -->
</div>
Thank you so much.Its working fine. how can I use ng-repeat here to split the values?
Hi
Something like :-
ng-repeat="announcement in data.announcement"
now here announcement will be your iterator like in for(var i=0;i<something;i++) "i" is your iterator.
