How to call System Property in scheduled job script
Sana10
How to call System Property in scheduled job script.
Surya66
Mega Guru
gs.getProperty() will always be the way you can retrieve a property on the server side.
In regards pulling a property on the client side, you have two options:
a) using a scratchpad and a display business rule to make the property available to the client as soon as a form is loaded
b) using a GlideAjax to call a script include which returns the property.
Prateek kumar
Check this article from Mark
https://www.servicenowguru.com/system-definition/working-with-system-properties/
Please mark my response as correct and helpful if it helped solved your question.
-Thanks
sachin_namjoshi
Mega Patron
Please use gs.getProperty() function
var attachment_link = gs.getProperty('glide.servlet.uri');
gs.info(attachment_link);
https://developer.servicenow.com/app.do#!/api_doc?v=kingston&id=r_ScopedGlideSystemGetProperty_String_Object
Sachin
