How to capture notification in work notes
shweta14
How to capture notification in work notes.
I have requirement When notification send it should capture to work notes.
Could you please help me to achieve this
18 REPLIES 18
have you checked sys_email table whether emails are getting triggered ? if not something wrong with the way notification is being configured
PavanK960672992
Mega Patron
hi,
try this in the email body.
${current.work_notes.getJournalEntry(1)}
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
Avinash_Patil1
Giga Guru
Please check if the Type of that notification is sent or not in sys_email table?
if not then set it to sent and then refresh and check.
Thank you for reply!
type of notification is sent but still not showing in work notes(journal input)
