How to Close Problem Record when only all related incidents closed
chanikya
i want to close PRB when related incidents all closed, if even one incident is in Working Progress then PRB should not closed.should be close all incidents then after only close PRB.
Sure. Just add this line below the addActiveQuery line. inc.addQuery('state', '!=', 6);
12 REPLIES 12
Mark,
your script is working fine, but is it allowing only iwhen INC is closed, can we able to give access even if INC is resolved
Hi Chanikya,
Please try the below modified code of Mark's.
inc.addQuery('problem_id', current.sys_id);
inc.addQuery('state','!=','6');
inc.addOrCondition('state','!=','7');
inc.query();
if(inc.hasNext()) {
// If we find even one incident open, abort the update
current.setAbortAction(true);
gs.addErrorMessage('One or more incidents is still open and must be closed before closing this problem record.');
VigneshMC
Try an before update BR when state changes to closed.
	var incident = new GlideRecord('incident');
	incident.addQuery('parent', current.sys_id);
	incident.addQuery('parent.state', '!=',7); //closed
    incident.addQuery('parent.state', '!=',6); //resolved
	incident.query();
	var count = incident.getRowCount();
	if(count != 0){
		gs.addInfoMessage("You have "+count+" open incident  which must be completed before this record can be closed");
not working
