How to copy attachments from incident to problem
Shiva prasad t
When we are trying to create problem from incident, the attachments are not copying / getting duplicate vice versa.
When: on Update
Condition: Problem is not Empty
function executeRule(current, previous /*null when async*/) {
var gr = new GlideRecord('problem');
               gr.addQuery('sys_id',current.problem);
               if(gr.next())
                                             gr.problem = current.sys_id;
                                             gr.update();
                                             var temp = GlideSysAttachment.copy('incident',current.sys_id,'problem',current.problem);
})(current, previous);
Raghu Ram Y
Try like below.
	var gr=new GlideRecord('problem');
	if(gr.next())
	GlideSysAttachment.copy("incident",current.sys_id,"problem",gr.sys_id);
	gr.update();
Hi @fred ,
here is the script which you might want to Refer/use:
Business rule: Copy Incident attachment into Problem
after
table : sys_attachment
insert, update checked
Script:
var atta = new GlideRecord('problem');
  atta.addQuery('parent', current.table_sys_id);
  atta.query();
  if(atta.next())
  var gr = new GlideRecord('sys_attachment');
  gr.addQuery('table_sys_id', atta.sys_id);
  gr.deleteMultiple();
  GlideSysAttachment.copy('incident', current.table_sys_id, 'problem', atta.sys_id);
current.update();
Sandeep
ersureshbe
I would recommend to use below article. As per Service now best practice dont copy the attachment instead you can display the attachment under related attachment tab
. https://community.servicenow.com/community?id=community_blog&sys_id=928c2ae1dbd0dbc01dcaf3231f961927
Suresh.
shloke04
Hi @fred
I learnt recently from one of the expert that copying attachment is not a recommended approach and it makes sense as well as it duplicate the attachment on multiple tables which from Architectural point of view is not a recommended approach.
Suggested approach would be using the related list as below:
However if still you need to go down the path and you need Attachment then I would suggest use Flow Designer approach as using Glide Attachment Copy will duplicate the attachment as by default it copies all the attachment every time the API is called and leads to duplication.
Navigate to Flow Designer and click on New and then Select Flow.
Then fill out the form and make sure to select it as Run as System User as shown below:
Now build your flow as shown below:
Final Flow will look like below:
Sharing Individual screenshot of the flow as well:
Trigger Condition:
This will not duplicate the attachment when it is updated. This works as well in my PDI have tested it .
Shloke
