How to create a incident widget with custom filter
luis_sportium
Mega Contributor
Hi all,
I need to create several widgets that display incidents filtered by region.
The presets that I can add only filters by user and incident status but in that case the user it ´s the same for all regions.
Thanks in advance
Luis,
Thank you for the screen shot.   Those filters can be configured by going to "System Definition -> Filters".   On that table you can create a new record, assign a name, set the table to incident, and then configure your filter.   Then when adding content to your homepage, under Filters -> Incident, you should see the new filters.
Note: your instance will automatically display 5 entries (one for each view) for each filter record you create.
Brian
Yeah!
Thank you so much Brian, that was exactly the answer
