How to create RITM through script ?
Geetha9
Ankur Bawiskar
you need to use Cart API
sample script below
try{
	var cartId = GlideGuid.generate(null);
	var cart = new Cart(cartId);
	//add your requested item to the cart by sys_id of the catalog item
	var item = cart.addItem('0336c34407d0d010540bf2508c1ed096', 1);
	//fill in the variables on the request item form
	cart.setVariable(item, "asset", "00a96c0d3790200044e0bfc8bcbe5dc3");
	cart.setVariable(item, "multiple_choice", "Phoenix");
	var rc = cart.placeOrder();
	gs.info(rc.number);
catch(ex){
	gs.info(ex);
Hope you are doing well. Could you mark the responses as correct/accept the solution so that this thread will be closed and will also benefit others in future.
