How to Delete Data Using Transform Map
hamauzutr13
We are considering importing an Excel file into the group member (sys_user_grmember) table.
This involves not only adding data but also potentially deleting data from the group members table.
We are exploring adding a deletion flag to the Excel file and using a Transform Script to branch the process based on the deletion flag value, handling data deletion and addition accordingly.
Could you advise whether this approach is feasible or if there is a better method?
Ankur Bawiskar
@hamauzutr13
Data load is usually done for insert & update and not for deletion.
Why not ask user to share separate excel or csv for data deletion and then you can read that file using CSVParser or ExcelParser and then delete the record?
@hamauzutr13
