How to delete/deactivate record with transform map?
AlbertoC9700865
I have to import a file with association to user and one group.
When a user is no loger in the the file it must be removed from the servicenow group.
How can I make this with a transform map?
kartiksethi
Hi @Alberto Comerro
Does the approach suggested by me worked for you?
Kartik
 @Kartik Sethi ,
Step 1 : Created test user in AD and then  through transfer map  in ServiceNow sys_user table created Teast user with Active true .
Now i have deleted Test user in AD and then trying transfer schedule job bit its not working only working for deactivated users in AD  if i will de-activate Test user in AD and transfer schedule execute after that ServiceNow sys_user table that Test User changed to Active 'False' --- this fine . i am looking for Deleted users .
if you know help me in this.
Thanks & Regards
PB
