How to disable all the mandatory fields using single function/command.
balaji_prusty1
Hi All;
In change form   we have lots of mandatory fields depends on the state/type of change. When user need to cancel the change he/she not to ask to fill the mandatory fields depends in which state he/she cancelling.
I can use g_form.setMandatory("FiledName" , false). But again I need to write code for all the mandatory fields (its around 30+) .
Is there any other way to remove/disable all the mandatory fields using single line code.
Thanks in Advance.
Balaji Prusty.
I am not getting the Close the loop / Answered   under Action....I was looking for this option.
All my previous threads are still open due to this...not sure what/whom need to contact to get this.
24 REPLIES 24
Hi Anurag;
Thanks it works. I have one question. Is the "g_form.checkMandatory = false" will apply to the fields which are in the Tab at down. here it is not working.
Is there anything I need to put to move out from mandatory for these tab fields ?
i dont understand
We have some mandatory fields in the Tab of the change form. It is not working if I put "g_form.checkMandatory = false".
So is there anything need to have to check these fields which are in the Tab ?
what is making this field mandatory? client script or something else
All the mandatory field set by UI Policy.
I think "g_form.checkMandatory = false" will not work for Data policy. But here we have all filed set for mandatory using UI Policy.
