How to disable side_door.do
erich_leitzbach
Hello.
One of my customers did a security audit to SNC application when using SSO.
The auditors came up with moaning about side_door.do to log into instance with local user profile when SSO is not working.
Now the question is if there are any ways to disable side_door.do and
a) only allow for specific users or
b) allow in certain circumstances with prior activation / enabling of side_door.do?
I know that this might cause the system to be inaccessible if SSO is crashed and side_door.do might not be working for ANY enduser.
For sake of discussion with auditors this might be taken as a theoretical situation and customer will need to be aware of high operational risks.
Any idea and argumentation is welcome.
Regards, Erich
cwilker10
Giga Expert
You can also investigate setting up an entry in sys_public for side_door and make it false.   jshatney has the right answer, though, if you don't have a local account then you can't use it successfully anyway.
-Chris
jshatney
Mega Expert
If a user does not have a local password in ServiceNow, they cannot login with the side_door.do
You can enable a specific set of users by setting a password for them in their user record.
cwilker10
Giga Expert
-Chris
