How to display an Info message in ServiceNow Portal
Priya131
How to display an info message for the service Now Portal when the incident form resolved state changes to the closed state.
Priya
20 REPLIES 20
Can you confirm, do you want to display an info message when the user change the resolved to closed - if yes above business rule should work.
Or if you want to display the info message for already closed incidents - Create an onLoad client script and set the UI type as Mobile/service portal.
function onLoad() {
    if (g_form.getValue('state') == 7) { // set the correct closed state value
        g_form.addInfoMessage('The incident state is already closed');
Hi Balaji,
Yes, I want to display an info message for already closed incidents in the service portal.
I have tried the onload client script as well, it was not working, Please help me on this issue.
Priya
did you check the state field is present on form
try this
if(g_form.getValue('state').toString() == '7'){
I have tried, It's not working.
which form/page you are checking this?
Did you check the onLoad is running? try adding alert and check
