How to Display fields on basis of catalog task
puneetgoels1
In my workflow, there are around 20 catalog tasks and there are 100 fields all together. I need to display selective fields on the basis of catalog task e.g. task 1 show 5 fields and hide others, task 2 show 10 fields and hide others and like wise.
How can it be achieved efficiently?
puneetgoels1
Correct Answer: Catalog UI Policy or UI policy do not work on the conditions on short description of task. It works only for catalog item variables and short description like fields be it at request item level or catalog task level in scoped application.
So the way to achieve it is write a UI policy at global level, put a condition for the catalog item and use the script to implement it
40 REPLIES 40
Where did you write the script? I mean on which table?
Table?
I am writing in catalog client script and/ catalog UI Policy. It will take the default tables for catalog item
Write on sc_task table
Invalid 'Table' selected on the Catalog Client Scripts record. The 'Catalog Task' table is in application 'Global', but the current application is 'WDAT SOE'.
Write Client script not catalog client script.
