How to display "When an incident has a knowledge article attached the Knowledge articles "Incident" tab should reflect/populate the incident # that was attached to said article.
06-30-2020 02:48 AM
07-01-2020 05:37 AM
in my case when I enabled the knowledge article checkbox just before closing incident it populated the source with the incident detail
10-20-2021 11:37 PM
Hi Raj,
Hope you are doing good.
Would you mind marking the best matching answer as correct and helpful, to close this thread?
07-21-2021 11:54 PM
Hi Raj,
07-05-2020 04:49 AM
Did you get a chance to read through my previous comment?
Do let us know if stuck
07-05-2020 10:19 PM
Hello Ankur,
Yes i got stuck,As i'm new to this Relationships i'm still not getting where can i make the changes and as i mentioned in above comment source field is showing empty and no other field is storing Incident no in knowledge article related list.
Please help me here if any details required i can provide you.
