How to display "When an incident has a knowledge article attached the Knowledge articles "Incident" tab should reflect/populate the incident # that was attached to said article.
06-30-2020 02:48 AM
07-06-2020 01:13 AM
So you tried the script I shared for query on m2m_kb_task table and it worked
what issue you are facing now?
07-06-2020 04:05 AM
You got me wrong, i added the existing related list and couldn't find where did it came from.
07-06-2020 04:21 AM
did you check in left nav relationships you are able to search that?
