01-29-2022 02:27 AM
I want to list all the Incident tasks associated with Incidents which are listed from the "Incidents" tab. Similarly what we have in Incident form but here I want these incident tasks listed from the Problem form. How can I do this?
01-29-2022 02:55 AM
You will need custom relationship. Since it is a bit tricky to understand the Parent and current object, I will provide you with the code.
First - go to System Definition - Relationships. Click new and defined as per the screenshot.
TThen go to the problem form, click the context menu - configure - related lists
FFind the one that you just defined and move it to the right slushbucket. Save.
And here we go - you have the new related lists, showng tasks, that are related to the related incidents of your problem.
Please Mark Correct AND Helpful. Thanks!
01-29-2022 02:55 AM
01-29-2022 03:14 AM
It worked.. Thank you
