04-14-2026 08:40 PM
Hello everyone!
I have a catalog item, where I have a reference field which is referring to a custom table, My issue is when i start typing in this field, it is not poping out matching values. Could you please help me, how to make this work> Here are some screenshots and variable attrubute i tried so far.
04-15-2026 01:37 AM
how many such records are there?
any leading space is there in that text?
04-14-2026 10:19 PM
any query business rule is blocking some records?
04-15-2026 01:04 AM
@Ankur Bawiskar there is no Query BR on this Table. When I am searching with * then values are populating but when just typing then some of the values are not showing in matching records,
04-15-2026 01:37 AM
04-15-2026 01:48 AM
Hi @Ankur Bawiskar Thanks this was the real culprit, there was trailing spaces in some of the Products, I removed them and working fine now. Thanks Again!
04-14-2026 09:19 PM
Hi @sunil maddheshi ,
This issue occurs because reference fields search only on the Display field by default.
Fix:
- Go to your referenced table (e.g., u_products)
- Make sure the field users search (e.g., product name) is set as Display = true
OR
Use variable attributes for multi-field search:
ref_auto_completer=AJAXTableCompleter,ref_ac_columns_search=true,ref_ac_columns=u_productAlso, verify:
- Data exists in the field
- User has read access (ACL)
Mark this as Helpful if it clarifies the issue.
Accept the solution if this answers your question.
Vaishnavi
Technical Consultant
