how to exclude 2 members from group approval
kamer
Kilo Expert
How to exclude only three users from group approval in workflow. I am using Approval user activity.
Here is my script which is going for group.
var gr = new GlideRecord("sys_user_group");
gr.addQuery("parent", current.u_designated_cab);
gr.addQuery("type","CONTAINS",'6aa67778dbf40700e907572e5e9619cd');
if (gr.next()) {
answer = gr.sys_id.toString();
let me now how to filter out members from this group
Brad Bowman
Mega Patron
If your script is the best way to get to the group in question, that's fine for starters, then you would run this script inside the if block instead of your answer line.  Otherwise, just use this script with a hard-coded group sys_id if it will always be the same
answer = [];
var mbr= new GlideRecord('sys_user_grmember');
mbr.addQuery('group', gr.sys_id.toString()); //or use following line instead
//mbr.addQuery('group', '1'); //replace 1 with sys_id of group
mbr.addQuery('user','NOT IN','1, 2, 3'); //replace 1, 2, 3 with sys_ids of users to exclude
mbr.query();
while(mbr.next()){
answer.push(mbr.user.toString());
Ankur Bawiskar
you should be knowing which members to exclude from that group
1) form an array of those users sys_id and use that in query as below
answer = [];
var groupSysId = '';
if (gr.next()) {
groupSysId = gr.sys_id;
var sysIdArray = ['sys_id1', 'sys_id2', 'sys_id3']; // give here the 3 user's sys_ids
var member = new GlideRecord('sys_user_grmember');
member.addQuery("group", groupSysId);
member.addQuery("user.sys_id", "NOT IN", sysIdArray);
member.query();
while(member.next()){
answer.push(member.getValue("user"));
Mark Correct if this solves your issue and also mark 👍 Helpful if you find my response worthy based on the impact.
