How to exclude OOB notifications for some catalog items
Premkumar1
Giga Expert
How to exclude OOB notifications for some catalog items. I tried SysID is not in conditions but it is not working.
Notification is configured in Sc_request Table. Any help will be highly appreciated
You will need to change script as following, also add proper SYS IDs
answer = checkResult();
function checkResult(){
	gr.addEncodedQuery('request='+current.sys_id+'^cat_itemIN060f3afa3731300054b6a3549dbe5d3e,060f3afa3731300054b6a3549dbe5d3e');  //Replace with a comma separated list of your catalog item SYS IDs
	gr.query ();
	if (gr.next())
	    return false;
	else
	    return true;
13 REPLIES 13
	gr.query ();
	if (gr.next())
	    return false;
	else
	    return true;
Can we use the same script on Approval table's notification?
I tried this script but it wasn't working for Approval table's notification
MimiK
Hi @Alikutty A
Thank you so much. The script works.
mmk
Premkumar1
Giga Expert
Thanks Its working
