How to exclude RISK CONDITIONS for Risk assessments
Sathwik1
How to exclude RISK CONDITIONS for Risk assessments?
For OOB Risks, Risk conditions will work right? but for risk assessments also RISK CONDITIONS are working.. how to restrict it? and also Risk Assessment is not setting right risk as per the thresold value..
can someone please help me on this requirement?
@Ankur Bawiskar , @SanjivMeher @Manmohan K @Community Alums @Amit Gujarathi
Raghu Ram Y
Hello @Sathwik1
This was the most awaited question I was looking for, I too came across this scenario where I spent plenty of time to under why it was happening, finally it's a simple thing.. just inactivate the OOB Risks and set the thresold to "1". It will work perfectly.
Please mark my answer as both HELPFUL and CORRECT, if it helps.
Raghu.
Hi @Sathwik1 ,
Then you will need to customize a lil bit !!
Go to SetChangeRisk script include and comment out below lines:
Go to RiskAssessmentCalculator script include and comment out below lines:
Hi @Sathwik1 ,
Actually you can focus more on "Go to RiskAssessmentCalculator script include" and update as per your requirement.
Raghu Ram Y
Hello @Sathwik1
Raghu.
Hi @Raghu Ram Y ,
I am facing the same issue even after setting the field values of risk assessment. I am getting this error. How to resolve this , Can you help me with this?
