How to fetch a substring from a string from an email body
Sandeep109
Mega Contributor
i actually need to retrieve a substring from a string and that too from a email body, and all this is related to inbound email actions where the email is triggered from a tool to our instance and from there i need to retrieve
For example: In the email body we have the below data for Configuration and Description and we need to fetch only 'ZSNH36TJ50-000YT-100YDT' from configuration
Configuration : ZSNH36TJ50-000YT-100YDT in New Jersey,  USA
Description:Power is down
The script i used
if (email.body.configuration != undefined)
var res = email.body.configuration;
var sec=res.substring(0,24);
But neither the string in configuration is getting fetched nor substring is fetched
Could you please help me with the code
Thanks and Regards,
Sandeep
I don't know what you have in your script at this point, but what I've included above would work as a 1 line solution to your problem.
So this...
can simply be changed to:
var res = email.body_text.split("Configuration : ")[1].split(" ")[0];
or try:
var res = email.body_text;
var sec = res.split("Configuration : ")[1].split(" ")[0];
Now "res" (in the first example) has the outcome that you want and can be used elsewhere in your script or "sec" (in the second example).
_ChrisHelming
If the space is there and you're unable to use email.body.configuration you could use a regular expression on the entire email body looking for the match.
email.body.match(/Configuration : ([^\s]+)/);
vkachineni
var config = "Configuration : ZSNH36TJ50-000YT-100YDT in New Jersey,  USA";
var id = config.split(":")[1].trim() || ''; //If for some reason it could not split, default to ''
if(id != ''){
    id = id.substring(0,23);
gs.print(id);
