how to fetch the incident attached with problem records through business rule?
jiu
Hi, you can write a BR on the problem record and you can fetch the records. However be careful if the no. of incidents are high in your system, then this could affect the performance of the system as well.
Create BR on problem record
When: Display
Select Advanced
// Add your code here
gs.info("problem number is"+current.number);
var inc = new GlideRecord("incident");
inc.addQuery("problem",current.number);
inc.query();
while(inc.next()) {
gs.info("Incident is "+inc.getValue("number"));
})(current, previous);
Kindly mark my answer as correct if this works for you.
19 REPLIES 19
Andrii
What is your business need? There could be more than one incident related to the same problem record
jiu
i wanted to fetch the incident record which is related to that particular problem
When: Display
Select Advanced
inc.query();
while(inc.next()) {
jiu
above code is not working ..
