How to find tables created with installed plugins
vamshi2
Hello team,
How to find which table is created with which plugin
change risk assessment threshold table is created in instance when one of the plugin is installed?
Thank you,
Hi Vamshi,
Glad to see my answer helped You.
Kindly mark the applicable answer as Correct & Helpful both such that others can get help.
Sandeep
Musab Rasheed
Check below links
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0716467
https://docs.servicenow.com/en-US/bundle/tokyo-platform-administration/page/administer/plugins/task/find-components.html
Also, you can try to check Plugin documentation to see which table is activated as part of Plugin activation.
Musab
Hello rasheed Thanks for inputs If possible could you please tell me with an example so that I can understand more I want table names which is created with plugins Thank you
This link has proper steps please check that out.
Musab
