How to force inputting 2 decimal places for a number field in client scripting?
Si Min
Giga Expert
I have a field which created under single line text and having below client script to only accept numbers plus a period to indicate as price.
How do I round the value with 2 decimal point? And restrict them to only inputting 2 decimal point if user chooses to enter decimal values instead of rounding figures.
	var reg = /^[1-9]\d*(\.\d+)?$/;
	var ans = g_form.getValue('estimate_price_sgd');
	if(!reg.test(ans))
		alert('Please enter a valid price under SGD currency.');
		g_form.clearValue('estimate_price_sgd');
Thanks in advanced!
Hi there,
Because your image shows a Variable, you are talking about a Catalog Client Script? And not Client Script?
Is that correct?
If so:
No need to go for scripting.
Check out the functionality which sinds Madrid is available:
(I see version Madrid in your post)
https://community.servicenow.com/community?id=community_article&sys_id=f5b8a988db057300d82ffb2439961...
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Lukasz Bojara
Just a thougth, why using a text filed for a price (maybe you have a reason for it)? It is better to use type Decimal or Currency, this way you will not have to worry about the value validation, e.g. Decimal filed is a number with up to two digits after the decimal points (for example, 12.34), or Currency that can take up to 4 decimal places but you can switch is off in sys_properties to limit just to 2 (it is a default setting). With those field types, you do not have to write additional code to ensure that a valid number was given.
Best regards,
Łukasz
Hi Lukasz,
Thanks for the reply, but in the variable types I do not see there's a 'Curreny' or 'Decimal' from the selection to choose.
Hi there,
Is that correct?
If so:
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Hi Mark,
Great help!
This is exactly what I am looking for.
Thanks!
