How to get catalog variable values in business rule ?
Gopi22
How to fetch catalog variable value in an after business rule.
I tried --> current.variables.<variable_name>  but not working correctly.
Gopi
17 REPLIES 17
Hi Allen,
The requirement is that, when I submit a catalog item say catalogA, the BR should consider one particular variable value from that RITM - Yes or No value - if the value is 'No', then the BR should submit a new request this time for catalogB. Also, the variable value from catalogA should be updated in catalogB variable as well.
I have written an after insert BR. Below is the script I am using:
    gs.log("Form field value is: " + current.u_requested_foor); // This is displayed
    gs.log("Variable editor variable value is: " + current.variables.user_name); // This is shown as undefined
    var cart = new Cart();
    var item = cart.addItem('6ad1a41cdb7d22406ba15aa9bf9619a0');
    cart.setVariable(item, 'requested_for', current.requested_for);
    cart.setVariable(item, 'token_options', 'software_token');
    var cartGR = cart.getCart();
    cartGR.requested_for = current.variables.user_name;
    cartGR.update();
    var newSerReq = cart.placeOrder();
    //newSerReq.opened_by = current.caller_id;
    newSerReq.update();
    current.correlation_id = getRITM(newSerReq.sys_id);
    current.update();
    function getRITM(serReq) {
        var ritm = '';
        var grRITM = new GlideRecord('sc_req_item');
        grRITM.addQuery('request', serReq);
        grRITM.query();
        if (grRITM.next()) {
            ritm = grRITM.sys_id;
        return ritm;
})(current, previous);
Please let me know if you need more information.
Gopi
Gopi ,
what are your trigger conditions for your BR?
and are you sure in this line the field name is u_requested_foor? or its a typo error which should be u_requested_for ?
Reason behind checking this is  even if a field name is incorrect it might stop the execution of the script at that line .
also share your br TRIGGER CONDITiONS and is it a after insert or update BR ?
Mohith Devatte
Tera Sage
helllo gopi,
usually this is the correct syntax that you followed
current.variables.your variable name
but better check your variable name properly
and also can you share your script ?lets debug
Hi Mohith,
I am putting 2 log statements as below and only the first one works.
gs.log("Form field value is: "+current.u_requested_foor); // this is the requested for field on the RITM form
gs.log("Variable editor variable value is: "+current.variables.user_name); // this is the user name variable in variable editor in the same RITM form
Gopi
Ideally, above should work. Are you sure the RITM you checking log for has user_name variable used?
