‎09-25-2020 03:58 AM
I have a catalog item where end user attach a txt file with some data on it.How can i get access of attachment data's in flow design?
‎09-28-2020 10:01 AM
end user when attaches file to catalog during submission it gets attached to the RITM record.
From that you can use the Lookup attachment action and then the custom flow action
‎09-25-2020 09:44 AM
Hi Siraj,
You can refer below link for reference and convert this as a custom action.
‎07-03-2023 03:39 AM
can you share the flow that you used for that requirement.
please help me to achieve the task
‎07-03-2023 11:04 PM
can you share the flow that you used to do the flow for catalog item where end user attach a txt file with some data on it.
can you please help me to achieve it.
‎07-06-2023 02:10 AM
Hi, sraj
could you please explain how you achieve that task, i have a similar task like that so could you please help to achieve it
