How to get the display value of a reference variable in Script Include?
User205031
ga.addParam("sysparm_groupid", g_form.getValue("app_name")); is the reference variable in client side which passes the sys_id to script include of the record.
var nam = this.getParameter('sysparm_groupid'); -> I am getting the sys_id of the record in Script Include
I want to get the display value of this record to query that in a table.
I have used getDisplayValue but it is not working.
var t = nam.getDisplayValue();
Please help!
9 REPLIES 9
If you are running this script on tables please use the script as Anurag suggested.
Murthy
Murthy
I thought you are working on the catalogs/record producers.
Murthy
On the ritm, you can read the variable using the same script I gave.
Im not sure what you gave will work on RITM or not, I think it will just print the RITM number(or tickets display number).
-Anurag
Hi Anurag,
Thanks for the reply.
I thought he is asking about the display value of the reference field in the catalog form
that's why I gave g_form.getDisplayValue('variable_name');
but yes this wont work for tables.
Murthy
Murthy
Yup, Cheers!!
-Anurag
