12-24-2025 05:56 AM
Hi Team,
I have a flow designer, Once I submit the item, Ritm and sc_tasks are creating.
Now in sc_task short description I want to add one of the variable value in it.
I have added above one in my flow designer Action, this is coming in below way
Below is how my variable values are showing in catalog form
How to do this? Do I need to create any other Action
12-26-2025 12:04 AM
1 thing to check -> if that variable is select box then why it shows Search Icon
try this other way in script
Also check if there is any space in the variable name
var choiceLabel = fd_data.trigger.request_item.variables.addon_licence_project.getDisplayValue();
return choiceLabel;
12-26-2025 01:42 AM
with string type flow variable you can store any display value in it for Reference, list collector, select box etc
