How to get two input boxes by using spModal?
Sathwik1
How to get two input boxes by using spModal... by using the below I am getting one..I need one more input box as well..
function(spModal) {
  var c = this;
  c.onOpen = function() {
        //ask the user for a string
        spModal.open({
            title: 'Give me a name',
            message: 'What would you like to name it?',
            input: true,
            value: c.name
        }).then(function(name) {
            c.name = name;
@AnirudhKumar
AnirudhKumar
Hello Sathwik,
That maybe possible with embedding a widget in the spModal.
Frankly I have never used spModal for popups, I always go for the traditional Modal Window.
Here's the link :
https://www.w3schools.com/bootstrap/bootstrap_modal.asp
Using Modal window you are free to create as many input boxes, forms or anything you need inside your pop up.
Difference between spModal and Modal Window
SpModal Modal Window
Built by ServiceNow, works only inside ServiceNow portal Its open source concept, can be used anywhere
Makes it easy to quickly create simple popups
Takes few extra minutes to do the same job
You only give parameters, and ServiceNow creates the elements
You have to write out the HTML tags manually
Complex designs are harder to achieve, due to lack of transparency (knowing what is going on)
Even complex designs are relatively easier achieve (we can see what is going on coz we write the HTML tags from scratch)
Learning how to use Modal Window takes some effort, but after 1-2 days, you will fall in love with it.
Filipe Cruz
Hello!!
Please check the following link that, for sure, will help you!
Workspace UI Actions
You can use a code like this:
function onClick(g_form) {
    var fields = [{
        type: 'textarea',
        label: getMessage('Reason'),
        mandatory: true
            type: 'choice',
            label: getMessage('Reason code'),
            value: getMessage(' -- Select -- '),
            choices: [{
                displayValue: 'Because I want to',
                value: 'illdowhatiwant'
                    displayValue: 'Not sure',
                    value: 'notsure'
            mandatory: true
            type: 'reference',
            label: getMessage('What is your name?'),
            mandatory: true,
            reference: 'sys_user',
            referringTable: 'incident',
            referringRecordId: g_form.getUniqueValue()
    g_modal.showFields({
        title: "Enter your reason",
        fields: fields,
    }).then(function(fieldValues) {
        g_form.setValue('work_notes', fieldValues.updatedFields[0].value);
        g_form.setValue('caller_id', fieldValues.updatedFields[2].value);
        g_form.save();
And the result will be:
Is this what you are looking for?
If this answer is relevant for you, please mark it as correct/helpful.
Filipe
Nope,
I am looking for spModal which can be used in portal..
AnirudhKumar
Hello Sathwik,
Here's the link :
Thank You!
