How to hide Price and total field on Order status screen based on user role
Bhargava4
Mega Expert
Hi Gurus,
if you have  admin role your able to see price and total field order screen in both areas like SN and Service Portal, if not we need to hide those two fields. please post your thoughts
Maintain cart layout not for this requirement because we need to dynamical based longed user role
Brent Sutton
Hi Bhargava,
You would probably have to clone the OOB "SC Order Status" widget to do what you are describing. I would question the value of running your own widget rather than just configuring the widget instance to hide the price and total cost.
CTRL-Right Click "SC Order Status" widget >> Select "Instance Options"
Deselect "Display Price" and "Display Total Price"
Result:
This would hide the "Display Price" and "Display Total Price" fields for everyone (including admins) but would be much more supportable long term.
Let me know if this worked for you.
Brent
9 REPLIES 9
Thank you Brent. I will try this.
Ram chekuri
Nice. But I notice this affects all catalogue items. How do you make it to only affect a specific catalogue item request? I have some requests where I definitely need the Total column but for some I dont
I am trying to hide the Total price column and Recurring column in the SC Order Guide widget. But not seeing these checkboxes within Instance Options. How to enable them and then uncheck them?
flsn2
Hi guys does it take specific roles to be able to click on the instance options field ?
i cant click on it even as an admin
thx
Hi @flsn2, an admin will definitely have permissions to configure a widget instance. Just make sure that you're in the same application scope as the widget instance when you are making the change.
