How to implement granular delegation to ITSM (e.g. Request Management) ACL Rules
Sven Lieback
Greetings,
did anyone implemented the granular delegation (part of HRSD / additional plugin) for ITSM? It's really simple to define the delegation tables and delegation rules but I'm struggling with the ACL Rules. So e.g. for Request Management. If I order something and the department head has to approve. If a granular delegation is active and the approval is delegated to another department head, he (the delegate) is not able to open the ritm. I tried to implement/copy the "isAssignedOrDelegated" function of hr_delegation script include but I failed. Any ideas?
Many thanks, Sven
Hi @Christian Prob2 ,
I wrote an own delegationUtil script include with necessary functions. One of them I used for ACLs.
My read Access control rule for ritm:
if (new itsm_DelegationUtil().hasDelegatedApproval(current))
	answer = true;
Initialization of delegation Util:
var itsm_DelegationUtil = Class.create();
itsm_DelegationUtil.prototype = {
    initialize: function() {
		// BEGIN COPY FROM HR DELEGATION
		this.DELEGATION_PLUGIN_ACTIVE = GlidePluginManager().isActive('com.glide.granular_service_delegation');
		var maxRecordsReturned = gs.getProperty('sn_hr_core.delegation.max_records_returned_limit.override', '');
		maxRecordsReturned = maxRecordsReturned && !isNaN(Number(maxRecordsReturned)) ? Number(maxRecordsReturned) : '';
		this.MAX_DELEGATE_RECORD_RETURN = maxRecordsReturned;
		// END COPY FROM HR DELEGATION
/* MY FUNCTIONS
    type: 'itsm_DelegationUtil'
The hasDelegatedApproval function:
//checks if the record has an active delegated approval to the current user
	hasDelegatedApproval: function(record, userId) {
		if (!record || !record.isValid())
			return false;
		if (!userId)
			userId = gs.getUserID();
		var targetTable = record.getTableName();
		var documentId = record.sys_id;
		// GET ALL APPROVALS FOR USER
		var approvalGr = new sn_delegation.DelegationUtil().getDelegatedApprovalsForUser(userId, true);
		var hasApproval = false;
		while (approvalGr.next()){
			// CHECK FOR DELEGATION (maybe optional)
			if (approvalGr.document_id==documentId && approvalGr.source_table==targetTable){
				hasApproval = true;
			if (hasApproval) {
				return new sn_delegation.DelegationUtil().isRecordDelegatedToUser(userId, approvalGr);
		return false;
Hope that helps 😉
Sven
