How to make attachments mandatory in portal for only specific software's in the software table?
Ramya66
There are some software's in software table for which if user selects that particular software in portal, then attachment must be mandatory.
Ankur Bawiskar
you can refer my blog which works in native+portal; enhance it as per your requirement
If it helps please mark it helpful and also bookmark it
Verify Mandatory Attachments Count on Catalog Item
Hi @Ramya
Did my solution didn't worked?
Gaurav Shirsat
Hello
Please refer the Article by Abhishek on possible ways to make Attachments Mandatory in Portal.
Mark my Response as Correct or Helpful, if you find it Appropriate.
Gaurav Shirsat : ServiceNow Community MVP 2022
https://www.linkedin.com/in/gauravshirsat/
Ankur Bawiskar
@Ramya
