how to make fields read-only based on group
max_danielewicz
Giga Expert
Hi There,
I would like to make some fields read-only when a change reached the authorized state. This should apply to all users except those in the change managers.
i created a ui policy which applies when status is one of (authorized, scheduled, implemented, review and closed).
Unfortunately, the condition is not working, however, if i remove the condition will make the fields read-only for everyone.
additionally i added a script:
execute if true:
function onCondition() {
if (g_user.hasRoles('change_manager') == false) {
  g_form.setReadonly('short_description',true);
  g_form.setReadonly('justification',true);
  g_form.setReadonly('implementation_plan',true);
  g_form.setReadonly('risk_impact_analysis',true);
  g_form.setReadonly('backout_plan',true);
  g_form.setReadonly('test_plan',true);
  g_form.setReadonly('start_date',true);
  g_form.setReadonly('end_date',true);
i would prefer to change conditional for membership group instead.
any help will be appreciated.
max
shloke04
This can be done using the UI Policy as shown below:
In the Run Script section of UI Policy write the below script:
Script:
if(!g_user.hasRole('change_manager'))
  g_form.setReadOnly('short_description',true);
  g_form.setReadOnly('description',true);
This is working fine for me in my personal instance. Please test the same from your end too.
Hope this helps.Mark the answer as correct/helpful based on impact.
Shloke
Shloke
shloke04
Script:
Shloke
Shloke
