How to Make variables read only after task sets to closed completed in ritm form
Nag9
Hello Community
I want to set variables tab read only mode on ritm form for non admins to some specific catalog items.
As of now its is working correctly, But  once Y task sets to closed complete on ritm form then only variables should be in read only mode. Now its working once ritm generated, the restrictions on this tab should only apply after this(Y) task is closed
How can we achieve this Here is the codes
Script include:
var MyGroups = Class.create();
MyGroups.prototype = Object.extendsObject(AbstractAjaxProcessor, {
isGrpMember:function() {
var userID = this.getParameter('sysparm_userID');
var groupID = this.getParameter('sysparm_groupName');
//get the group name based on the group id
gs.log("Entered the function of isGRP Member");
var gr = new GlideRecord("sys_user_group");
gr.addQuery("sys_id",groupID);
if (gr.next()) {
gs.log("Enered into the if condition of my script include");
var groupName = gr.getValue("name");
var thisUser = gs.getUser().getUserByID(userID);
if (thisUser.isMemberOf(groupName)) {
gs.log("Returned true becuase user is member of this group");
return true;
else {
gs.log("Returned false because user is not a member of this group");
return false;
} // end of if gr.next
type:'MyGroups'
 Client script:
function onLoad() {
var item=g_form.getValue('cat_item');
if (item=='e7d48d55db5f8b00c77b7016bf96199b' || item=='e386bfb3dba68700c77b7016bf961943' || item =='ae244264dbb6c700c77b7016bf961944' || item== '1813429bdb83c700f3e5f156bf9619e9' || item== '0d0c3f5adb28e3001ac0105f6896198e' || item =='f2377d15db9f8b00c77b7016bf96191c' || item=='f477b155db9f8b00c77b7016bf961967')
//g_form.addInfoMessage("Entered into if condition");
var ga = new GlideAjax('MyGroups');
ga.addParam('sysparm_name', 'isGrpMember');
//ga.addParam('sysparm_userID', g_user.userID);
ga.addParam('sysparm_userID', g_user.userName);
ga.addParam('sysparm_groupName',g_form.getValue('assignment_group'));
ga.getXML(hideField);
//g_form.addInfoMessage("Entered into the function" +answer);
//g_form.addInfoMessage(g_user.hasRole('admin'));
function hideField (response) {
var answer = response.responseXML.documentElement.getAttribute('answer').toString();
if ((answer == 'false') && !g_user.hasRole('admin')) {
g_form.setVariablesReadOnly(true);
else
g_form.setVariablesReadOnly(false);
asifnoor
Hi Nag,
I have updated the script. Check this once.
Script Include:
   var req_item = this.getParameter('sysparm_reqItem');
   if (gr.next()) {
       return true;
     else {
		//check if any of the catalog tasks are complete.
		return this._isCatalogTaskComplete(req_item);
   else {
	   gs.log("Entered into else");
  _isCatalogTaskComplete:function(req_item) {
	//fetch the associated catalog tasks which are closed complete for this RITM
	  gs.log("Entered into the 2nd function");
	var gr = new GlideRecord("sc_task");
	gr.addQuery("request_item",req_item);
	gr.addQuery("state",3);
	  if(gr.next()) {
		  gs.log("Entered into if of 2nd function");
		  return false;
		  gs.log("Entered into else of 2nd function");
		  return true;
 type:'MyGroups'
Client Script:
function onLoad() {
    g_form.addInfoMessage("Entered onload function");
	ga.addParam('sysparm_reqItem', g_form.getUniqueValue());
 else
Mark the comment as a correct answer and also helpful once worked.
Okay.
Kindly mark the comment as a correct answer and also helpful once worked.
Nag9
Thanks a lot asif its working for other users also, Finally its worked
miriamberge
At one point there were several posts about g_form.setVariablesReadOnly(true) not being supported by SN and to use at your own risk... is this now supported by SN?
